Dear Colleagues
1. In the attached video, I imported (.dxf file) to Robot. Some lines with overlapping. I changed the cad lines to bars. But I couldn’t merge them inside Robot although (Automatic bar merging during import of geometry option) (structure analysis in the job preferences) is activated.
Can you advise me, how to manage that?
https://www.mediafire.com/?npjvufdp186c5g4
2. I tried to understand from the help the meaning of (Adjust to background) in the wall dialog but I get confused with it.
May I know, what is the main purpose of it and where shall I use it? Please, will be more preferable if support your reply with an example capture which showing the difference between (with/without) using adjust to background option in the wall dialog.
Thanks in advance
Refaat
Solved by Artur.Kosakowski. Go to Solution.
Dear Refaat
There is no such function in RSA but you may want to use Rafal's macro:
http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-for-merging-bars/m-p/3817730
This is only for bars that have end nodes in exactly the same positions.
