One of the supporting columns doesn't appear in the design tab
Hello all,
When I'm designing two beams which are connected each other to a column, the column doesn't appear in the design tab and IDK why. The options are the same for all columns and beams and this problem just happens in this particular case. The model is attached for further assistance. Thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach the file please?
Artur Kosakowski
The model is to large to attach, perhaps because it was imported from REVIT.
I'm sending a link with my dropbox.
https://www.dropbox.com/s/izowyw06uozxqbv/Estrutura%20do%20Caso%20de%20Estudo%20Pilares%20Alterados....
Thank you
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
