- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to know how exactly analytical load transfer differs from one way load transfer in robot when it goes to the case of calculating one way slab.
I have rather simple case with a bridge deck slab supported on steel frame. The slab should work in one direction which is the transverse direction of the bridge so I have been considering of using the one way load transfer. However Robot seems not to distribute the load correctly as I get 0 reaction for the uniform loads on the slab. If I change the load transfer type to be analytical, then it works fine.
This then makes me wonder what robot is really doing with one way load transfer. I have understood it this way reading robot's description: all loads on the slab and the slab's own weight are distributed considering as if the slab's y direction has no stiffness, so in my case almost as if the slab is 2d (except for those enforced displacement). In my case, the Mxx moment should be flatter compared to the case using analytical for DL. However I only get error messages and robot seems not to understand loads applied on the slab. What did I understand wrong?
Attached is my model. I would very much appreciate if you could explain me this through!
Thanks in advance,
Fei
