"Load has not been distributed correctly - there are no objects or elements carr
Hi, good evening, i receive the following error when calculating my model:
"Load has not been distributed correctly - there are no objects or elements carrying the load overlap"
1. It detects there has to be any kind of problem with my model wich I suspect is in the roof panels because of required reinforcement.
Wind loads are applied just ok as checked at diagram results' window.
2. Was the modal seismic analysis properly done?
3. I ask if something unusual, mistakenly done or a bad practice was done, because it's the first time I use ARSA.
Note. I've played with the software for a few weeks with this program and watched some of the webinars and I feel kinda stucked.
PS. I attach the relevant .rtd model
Any thoughts?
