Punching reinforcements
5 REPLIES 5
1174 Views, 5 Replies
Hello everybody
I am calculating the reinforcement of one slab but I have a problem. The calculation of punching tell me that the reinforcements are not enough. When I saw the real reinforcements that Robot had put, I realized that the punching reinforcement was not put.
Why ROBOT never put the punching reinforcement?
In the following images you can see this problem:
Thank you for your attention
How can I put the punching reinforcement? I set this reinforcement as you can see in the following image:
5 REPLIES 5
Artur.Kosakowski
The punching forces Q are larger than allowed by the code Qadm for this concrete grade and slab thickness. Try to increase either or both of them.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
ok. Now supposedly there are punching reinforcements:
But I can not see this reinforcements in the following screen
How can I see this reinforcement?
Artur.Kosakowski
Punching reinforcement is neither generated on the reinforcement distribution view nor on reinforcement drawings.
Artur Kosakowski
Artur, do I understand correct description of punching reinforcement distribution?
Romanich
Hi @Anonymous , please check this thread
https://forums.autodesk.com/t5/robot-structural-analysis-forum/slab-punching-reinforcement-questions/m-p/7292976#M56458
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
