Hi guys,
How can I see all of the internal efforts of shear walls? I cann't define any cross-sections of the wall. Robot shows the nul results like the photo below.
Someone can help me? Plz.
Hi @Anonymous
From reduced result table right click then choose table columns then choose this Items:
1-From Result tab : Choose the forces to present
2- From Cut Tab choose the Cuts to be presented :
3- From Properties tab you choose thickness to present wall thickness.
Then press ok and you will see the wanted results.
Thanks @Artur.Kosakowski, I got somethings betters,
Hi @mustafahesenow I tried it, I chose all of type of cross sections, I m able to get non-nul results, but I don't understand what do these crosses mean? In what position of my wall?
Hi @Anonymous
Please check https://forums.autodesk.com/t5/robot-structural-analysis-forum/sending-bigger-files/td-p/3795062
Hi @Artur.Kosakowski @mustafahesenow
I finally found why it did not show. I just slightly changed the height of my shear wall and I got it. Thanks you.
