Hi everyone,
Could someone help me with this error "Problems with reinforcement arrangement" in the Reinforcement design of a foundation.
My file is in attachment.
I'm trying everything, no way to find where this error comes from.
Have a nice day,
Mathias.
Solved by Artur.Kosakowski. Go to Solution.
The pier size is too narrow for generation of reinforcement.
Hello sir @Artur.Kosakowski
I read this . But still not resolved my problem on the design of the beam as the number 108 for example. or reinforced concrete foundation at node 24.I attached pictures and models. Thank you.
For the beam mind the sizes of the supports:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
For the foundation you need to either allow for the sufficient pier size or switch off its reinforcement:
thank you very much. Yes, I discovered this afternoon too. Now there is another problem, can I design the reinforced concrete foundation eccentric as the picture attached to it??
Please create a separate topic for this new question so that it is easier for others to find the solution when it has been determined. Thank you.
@Artur.Kosakowski ha escrito:For the foundation you need to either allow for the sufficient pier size or switch off its reinforcement:
How can you switch off the reinforcement of the pier?
I am trying to check a footing of 40x40 cm and height of 30 cm without any pier. I am getting the reinforcement from the footing and from the pier, so I am getting this "thing"
I was expecting something like this:
Thanks in advance
