Problem with Extremas with cincomintants
gliga
Message 1 of 9
gliga
Well,
request is simple and not unusual.
For several similar columns and lot of ULS+ACC code combinations it is necessary to provide
ENVELOPE WITH CONCOMINTANTS
but
ONLY AT BOTTOM END OF COLUMN
(to provide connections for example)
FOR ALL COLUMNS AND ALL CODE COMBINATIONS
In RSAPRO2017 such request resulting in such screen
I am sure that this problem was not present in some of previous versions of RSAPRO
Situations with 2, 3...12 points work fine. Also with default characteristic points (when RSAPRO itself define points)...
Sincerely, Gliga
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach this model please? Thank you.
Artur Kosakowski
Message 3 of 9
gliga
It is model independent problem (I already check) and model is Huge, but OK
https://dl.dropboxusercontent.com/u/20766887/Model.zip
Select bars by section (HCHS 406.4x10), select "Code combinations"
"tables"
"forces"
"table filtered to current selection"
"Envelope",
"Table columns",
"Envelope"
"For all objects"
"Points"
"Characteristic points"
(delete all automatic generated points)
"x=0" (relative)
"Add"
"OK"
This should give Envelopes with concomitants for ALL bars AND only for bottom ends of the bars (columns) - totally 12 rows of data.
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
First of all thank you for notifying us about this situation.
Could you check if this solution works for you?
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 5 of 9
gliga
Yes, it work - but is not correct
In such results END POINTS exist too (you can check by yourself on same model) - it seems that such selection JUST ADD THAT POINT to beginning and end ones. As a matter affect it seems that you can not exclude START and END points in such selection.
So you can not trust to results until something like "x=0" appear in table, in all rows.
Sincerely
Message 6 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try this macro (it works for one selected node so you need to use it several times to extract all results you need):
http://forums.autodesk.com/t5/robot-structural-analysis/envelope-of-forces-at-a-connection-api/m-p/3...
Feel free to modify this macro according to your needs.
Rafal Gaweda
Message 7 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, indeed you are right. This option adds an additional point to origin and end ones so the result is not the one you'd like to see Smiley Sad
Artur Kosakowski
Message 8 of 9
gliga
New version of Robot and same problem?
Are you going to solve this?
Gliga
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @gliga
I'm not able to answer if or when as we don't have such knowledge but I can promise that we will post this information when this has been done.
Artur Kosakowski
