Problem in member verification of tapered elements
Dear members,
after the creation of Tapered section BOX2_V_2 (with different b1 values in start and end points) I had the problem to perform the Steel/Aluminium Design task of these elements. Interested elements for memebr verification are n° 1 and 2. Please find enclosed .rtd file and thanks in advance.
Marko
Artur.Kosakowski
Autodesk Support
Autodesk Support
What is this problem exactly? Please try to install SP5 for RSA 2015 and check if you have the same situation. Thank you.
http://knowledge.autodesk.com/support/robot-structural-analysis-products/downloads/caas/downloads/co...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
