Problem generating mesh (steel deck plate)
Message 1 of 8
I am having some trouble generating the mesh for the panels of the model. The system goes frozen and I have to restart it. I have tried to open it with the repair option with no success.
If I try to generate a mesh locally for each panel I obtain a weird combination of many FE and few FE.
Any help will be very much appreciated.
Kind Regards,
M
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 8
Thanks.
How do I find slide 37 (what minute of the presentation?)
Message 4 of 8
I have tried the options highlighted in the presentation without success. The model gets frozen during calculation at the same point as before - while generating the mesh. I cannot progress from here.
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 6 of 8
muthomimunyua
I have attempted the solutions as suggested on this thread and according to the webinar 6. However, my model still keeps hanging at  'Mesh regeneration. Number of objects. 149'. I have attached the model here for any assistance if possible. I am at intermediate level and I will appreciate any further advice/modelling strategies, philosophy etc...
Robot Job PreferenceRobot Job PreferenceRobot Advanced Meshing OptionsRobot Advanced Meshing OptionsRobot Structure Verification.Robot Structure Verification.
Muthomi Munyua
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @muthomimunyua
Keep in mind Your model is inaccurate.
For example walls are not aligned  (1272 1355 1273 1320 1321 1353 )
Slab 1340  arc is not "compatible" with bars circle.
Correct geometry , mesh walls first, then slabs, then most likely you will need to remesh some walls or correct meshes different way
Rafal Gaweda
Message 8 of 8
muthomimunyua
Thanks Rafal,
Indeed the model has some inaccuracies. I will follow your recommendations and those in Webinar 1&2 of Build your RSAPro IQ.
I highly appreciate.
Muthomi Munyua
