Print from help
Print from help
Jummybear
Print from help
Jummybear
I apologize if this theme is an offtopic but I wonder is there any chance to print whole topic with subtopics from the help/helpfile? For example I need to print all information about results connect with its subtopics. There are no print-friendly page view, no button for printing. So I need to print theme by theme by hand or copy everything to word and then print from there?
Artur.Kosakowski
Autodesk Support
Autodesk Support
In general from online help you can print only one page at the time.
For the offline help when you have Adobe Acrobat you should be able press the RMB at the topic in the table of contents to invoke the context menu. Then you can select Convert to pdf or Append to existing pdf to add the selected topics to a pdf and then print the entire pdf but I haven't tested these options yet.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
