Message 1 of 12
As soon as i use a release curve I get "No convergence of nonlinear problem".
Please help!
Please help!
Robot needs the value in the 0 point. In addition I set the FNR method.
Can You help me how to do it from API(VB).
Could you send me your code? What do you actually need:
- add 0, 0 point in the definition of release
- set FNR method for all cases and combinations
It is very long. I only need to know how to invoke the "matrix update after each iteration" from api, because that worked fine with 0,0 release point.
This is the code I am trying to use;
comb = robapp.Project.Structure.Cases.CreateCombination(7, "Lastfall 1", I_CBT_SLS, I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR) Dim NL_Params As RobotNonlinearAnalysisParams NL_Params = comb.GetAnalysisParams NL_Params.PDelta = True NL_Params.MaximumNumberOfBFGSCorrections = 0 NL_Params.MatrixUpdateAfterEachIteration = True comb.SetAnalysisParams(NL_Params)
Example code:
Dim Robapp As New RobotApplication Dim Scase As RobotSimpleCase Set Scase = Robapp.Project.Structure.Cases.GetAll.Get(1) Scase.AnalizeType = I_CAT_STATIC_NONLINEAR Dim RNAP As RobotNonlinearAnalysisParams Set RNAP = Scase.GetAnalysisParams RNAP.MaximumNumberOfBFGSCorrections = 0 RNAP.MatrixUpdateAfterEachIteration = True RNAP.MatrixUpdateAfterEachSubdivision = True Scase.SetAnalysisParams RNAP
Dim comb As RobotCaseCombination Set comb = Robapp.Project.Structure.Cases.CreateCombination(7, "Lastfall 1", I_CBT_SLS, I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR) Dim NL_Params As RobotNonlinearAnalysisParams Set NL_Params = comb.GetAnalysisParams NL_Params.PDelta = True NL_Params.MaximumNumberOfBFGSCorrections = 0 NL_Params.MatrixUpdateAfterEachIteration = True NL_Params.MatrixUpdateAfterEachSubdivision = True comb.SetAnalysisParams NL_Params
Still having problem with this as soon as I add release curves for bars 28 and 32
Just make sure you define (0, 0) point in for all versions of releases. In addition I set FNR method.
FNR?
Full Newton-Raphson. Check posts 4 and 5
