No convergence of nonlinear problem with only one non-linear release curve
jokiller70
Message 1 of 12
jokiller70
As soon as i use a release curve I get "No convergence of nonlinear problem".
Please help!
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Robot needs the value in the 0 point. In addition I set the FNR method.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 12
jokiller70
Can You help me how to do it from API(VB).
Message 4 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you send me your code? What do you actually need:
- add 0, 0 point in the definition of release
- set FNR method for all cases and combinations
Artur Kosakowski
Message 5 of 12
jokiller70
It is very long. I only need to know how to invoke the "matrix update after each iteration" from api, because that worked fine with 0,0 release point.
Message 6 of 12
jokiller70
This is the code I am trying to use;
            comb = robapp.Project.Structure.Cases.CreateCombination(7, "Lastfall 1", I_CBT_SLS, I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR)
            Dim NL_Params As RobotNonlinearAnalysisParams
            NL_Params = comb.GetAnalysisParams
            NL_Params.PDelta = True
            NL_Params.MaximumNumberOfBFGSCorrections = 0
            NL_Params.MatrixUpdateAfterEachIteration = True
            comb.SetAnalysisParams(NL_Params)
Message 7 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example code:
Dim Robapp As New RobotApplication
Dim Scase As RobotSimpleCase
Set Scase = Robapp.Project.Structure.Cases.GetAll.Get(1)
Scase.AnalizeType = I_CAT_STATIC_NONLINEAR
Dim RNAP As RobotNonlinearAnalysisParams
Set RNAP = Scase.GetAnalysisParams
RNAP.MaximumNumberOfBFGSCorrections = 0
RNAP.MatrixUpdateAfterEachIteration = True
RNAP.MatrixUpdateAfterEachSubdivision = True
Scase.SetAnalysisParams RNAP
Rafal Gaweda
Message 8 of 12
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dim comb As RobotCaseCombination
Set comb = Robapp.Project.Structure.Cases.CreateCombination(7, "Lastfall 1", I_CBT_SLS, I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR)
            Set NL_Params = comb.GetAnalysisParams
            NL_Params.MatrixUpdateAfterEachSubdivision = True
            comb.SetAnalysisParams NL_Params
Rafal Gaweda
Message 9 of 12
jokiller70
Still having problem with this as soon as I add release curves for bars 28 and 32
Message 10 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Just make sure you define (0, 0) point in for all versions of releases. In addition I set FNR method.
Artur Kosakowski
Message 11 of 12
jokiller70
FNR?
Message 12 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Full Newton-Raphson. Check posts 4 and 5 Smiley Happy
Artur Kosakowski
