Dear all,
I am having many questions concerning the model of prestressed concrete bridge in RSA.
That way is possible? or not is there the solution indirect to define cable in section of in the section of bridge??
Thanks a lot
Solved by Artur.Kosakowski. Go to Solution.
You may want to look at Autodesk Structural Bridge Design for these types of bridges instead.
Thanks for your response
So is there the French code? I mean the annexe for France?
Regards !
This is the list of available codes:
You may also check ASDB forum
