Pipe Column Beam Connection
nrogers58
Message 1 of 14
nrogers58
Trying to model the attached pipe as a pipe column. Robot does not allow for a pipe column beam connection design or does not have such a template.  Suggestions?
Thanks in advance for your interest and effor to reply.
Neal
Replies (13)
Message 2 of 14
Simau
@nrogers58
No file attached, try again
M. Agayr
Message 3 of 14
nrogers58
I do not see your suggestion
Message 4 of 14
Simau
You didn't attach any file
M. Agayr
Message 5 of 14
nrogers58
Let me try again.
Message 6 of 14
Simau
@nrogers58
you can design the lower anchor, but I do not believe that it is possible to make steel-wood connection
M. Agayr
Message 7 of 14
nrogers58
I am going to connect with bolts to a M 10 x 7.5
Message 8 of 14
nrogers58
When I go to connection definition it will not allow me to select a circular section in the P family.
Message 9 of 14
nrogers58
here is where I am. Left side for column does not allow P family pipe sections using AISC 15.
Message 10 of 14
Simau
Could you share your modele?
M. Agayr
Message 11 of 14
nrogers58
I should work on it some more before spending your time. Thanks
I will get back to you.
Message 12 of 14
nrogers58
I have completely reconfigured my model. I have tabled the steel pipe column design.  At first I added 6 x 6 RC columns fixed. I actually got the calculation to run wo an instability message. I had the "separate structure" penalty message.
So now I have added tons of concrete and added joist stiffiners.  No matter what I do, the building falls down.
I need help.
Thanks in Advance,
Neal
Message 13 of 14
nrogers58
I have compl,etely reconfigured the model.  I tabled the steel pipe columns (as presented by the clients draftsman). I added 6 x 6 RC columns and got to to no fall down. I did have the separate structure error. which continues.
Somehow between the RC columns and when I got the building to stand, the building is now falling down.  I have added tons of concrete and added joist stiffiners but no matte what the building falls down.
I need help. Please.
Thanks Yu
Neal
Message 14 of 14
nrogers58
Good Morning,
I am going to post on the forum. I suspect it is my wall design causing the problem.
Neal
