Load Label and Load Name
AliNajeeb
AliNajeeb
Hi all,
What is the different between Load Label and Load Name in RSA?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @AliNajeeb
I use case label for defined combinations presentation
In combination table cases are identified by number (as default)
You can switch to case identification by label by Right Mouse Button >Table columns
Krzysztof Wasik
Simau
Hi @Krzysztof_Wasik
Why in the combination table we can't see ULS label?
M. Agayr
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @Simau
It seems to be issue in Robot
ULS Combinations generated in automatic combination module have label ULS A.
They can be selected as ULS.A in case filter  in spite that type is not displayed in combination table
Krzysztof Wasik
