Panel - Storage nodes
polylouis
polylouis
Hi everyone,
I would like to storage nodes of panel in a list with python.
The aim is to browse the list to get FEdetail.MXX for exemple.
Actually I do like this :
for j in range(58,61😞
    FEParams.Case=j
    for i in range(0,41😞
        FEParams.Node = i
        FEdetail=structure.Results.FiniteElems.Detailed(FEParams)
        mxx_ELSF=(FEdetail.MXX)*0.001
        myy_ELSF=(FEdetail.MYY)*0.001
        mxy_ELSF=(FEdetail.MXY)*0.001
Could you help me to find the solution ?
Thank you in advance,
Regards
Louis
Stephane.kapetanovic
HI @polylouis
to extract the list of nodes from a panel
Dim Obj As RobotObjObject, ObjNo As Long, NodesLst As String
ObjNo = xxx ' < Panel Number
Set Obj = RobApp.Project.Structure.Objects.Get(ObjNo)
NodesLst = Obj.Nodes
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
polylouis
Thakn you for your answer @Stephane.kapetanovic .
I don't succeed this proposal. List returns none elements
I thought the following test :
objects = structure.Objects
object_number = objects.FreeNumber
objects.CreateContour(object_number, points)
contour = IRobotObjObject(objects.Get(object_number))
contour.Main.Attribs.Meshed = True
contour.Initialize()
contour.SetLabel(IRobotLabelType.I_LT_PANEL_THICKNESS, "Massif")
contour.SetLabel(IRobotLabelType.I_LT_PANEL_REINFORCEMENT, "REINF_massif2")
contour.SetLabel(IRobotLabelType.I_LT_SUPPORT, "Fix")
contour.Update()
NodesLst = contour.Nodes
 No=[]
No.append(NodesLst)
But it desn't work...
polylouis
Thank you for your answer @Stephane.kapetanovic .
objects.CreateContour(object_numberpoints)
contour.Update()
 No=[]
No.append(NodesLst)
hi @polylouis
you need to mesh first
Best regards
polylouis
hi @Stephane.kapetanovic
the result is :
[" 1to152 154to166 168to170 172to175 177to185 187 189to195 197to206  "]
Do you know how should I obtain each node in the list ?
Louis,
hi @polylouis
there are several ways to do this.
- create a function that returns an array from the text sequence. (it can be used in many places in your programs)
- create a virtual selection "Selections.Create(Type)", give it the text of the nodes with "Sel.FromText(List)" and iterate over a collection made of the selection.
Best regards
