Panel Cuts
Panel Cuts
Panel Cuts
Hi all,
Are "panel cuts" not available in building type of model??
Cheers,
Tony
Artur.Kosakowski
Autodesk Support
Autodesk Support
They are available. Use Results > Panel Cuts.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
I know that the panel cuts option can be selected using results --> panel cuts.
However on my model, the option is not in the drop down menu anymore.  It was there a few days ago, then dissapeared.
So I can no longer use panel cuts on that particular model.  If I open another model or start a new one the option mysteriously re-appears.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
You can customize menu by Tools \ Customize \ Customize menu , expand tree branches, click on red dot(s) to make them green -> green means displayed in menu.
Rafal Gaweda
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please try to change the model type to Sheel and then change it again to Building.
Artur Kosakowski
