Autocad dwg files import
GabrieleNovembri1027
Message 1 of 11
Hi All
I'm trying to import different types of elements from AutoCAD files. The behavior of Robot seems to me in this case absolutely incomprehensible. If I try to import a solid from a *. sat file created with Autocad Robot, correctly import a volumetric element but I can not import anything from dwg file (2012 version). Obviously, autocad 2012 is installed on  computer.
I can not understand:
1) The type of geometry of the Robot file (building, solid cc.) Influences the import process?
2) What elements of Autocad are imported ?:  solids, surfaces, meshes, or all three?
3) Where can I find a detailed description of the procedures, settings etc.?
Any suggestion ?
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
To import sat file you have to turn on ACIS (Solid Modeler) in Preferences
 Robot imports from line polylines arcs circles faces and meshes from dwg \ dxf file.
Solids - only as sat files.
Rafal Gaweda
Message 3 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm attaching the description of the settings for dxf/dwg import dialog. I hope you find this information helpful.
Artur Kosakowski
Message 4 of 11
Thanks.
Message 5 of 11
Hi
How can I import a panel structure?, Which type of Autocad element should be (3D face, Region, Mesh)?
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to import the outer boundaries of panels. You can import them as bars and use them to create panels either by indication a point inside such created contour or by selecting them during a panel definition. After creating panels they can be selected and deleted from the model.
Artur Kosakowski
Message 7 of 11
I am trying to turn on my ACIS, but in my Preferences > view parameters menu I do not have the solids modeling options. (see image).
Is there something else i need to turn on?
Timo
Message 8 of 11
Rafacascudo
Try in JOB preferences
Rafael Medeiros
Message 9 of 11
Simau
Here also nothing like that on Job preference
A second question:
Where can i find  "Parameters of loadings DXF/DWG-format files" as mentionned in files dxf_dwg_import.zip 524 KB  (post 1/8) above
M. Agayr
Message 10 of 11
Rafacascudo
Job preferences/Work parameters  for Solid modeler
dxf/dwg loading parameters will show up only when you Open a dxf or dwg inside Robot Through File /Open project
Rafael Medeiros
Message 11 of 11
Simau
Hi
M. Agayr
