Panel cut results
Panel cut results
HoshangMustafa
Advisor Advisor
Panel cut results
HoshangMustafa
Hi all,
Please find the attached rtd zip file.
As you can see, from View:3, A-A2 panel cut results show different moment results than hand calculation. I used ACI coefficients for calculating moments in one-way slab. I also attached hand calculation. What would be wrong with my model?
HoshangMustafa
99 views, 0 replies
HoshangMustafa
Hi all,
Is it ok to compare ACI moment coefficients with panel cut results? or is it ok to compare it with Maps results?
HoshangMustafa
130 view, 0 reply
@Simau@DonBAE, @raKrzysztof_Wasik@Rafacascudo
any help would be highly appreciated.
HoshangMustafa
another question:
I heard people would set bending stiffness of slabs to zero when designing T-beams using Finite Element Method. Is it right to use it in ARSA when designing T-beams?
