Odd result label behavior
Here's a screenshot:
Notice how at the midspan the moment labels suddenly go from 3034.48 to 1886.66, but the beam options diagram shows the correct behavior, which is nice and well-behaved.
I have not yet installed Service Pack 3, which I saw came out today but havent had the time to actually install.
The model can be seen here: https://dl.dropboxusercontent.com/u/3087637/JacareiTest.rtd
Artur.Kosakowski
Autodesk Support
Autodesk Support
Mind that you display values for top and bottom envelopes at the same time. This filter (combination +/-)  is intended for the tables.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
