Type 1 instability
Type 1 instability
Type 1 instability
Hi Rafael,
I have desinged a simple truss walkway but am getting type 1 instabilities in the pin supports in all directions (RX, RY, RZ).
The member utilization ratios are very small, but i cant seem to correct the errors unless i place bracing at the base of the supports.
Is there a solution without over designing the structure?
I have attached the model for your use.
Regards
Steve
Rafal.Gaweda
Autodesk Support
Autodesk Support
I think the releases on all columns should be defined as shown below:
Rafal Gaweda
Hi Rafael,
HOw come you have the Ry fixed for the right sided columns and free for the near side coloumns?
Would this also not create a moment in the pin connection? We are trying to avaoid that.
Steve
Rafal.Gaweda
Autodesk Support
Autodesk Support
Steve
Check results ; releases on beams do that
Check results  - see below
Rafal Gaweda
Hi Rafal,
I seemed to have solved the problem and was running the analysis error free.
I then made some adjustements to the type of bars< assigning columns, beams and bars, all of which have the same properties.
Please see the attachement to see the latest error.
Steve
Rafal.Gaweda
Autodesk Support
Autodesk Support
Correct defintion of Pinned-Pinned support below:
Rafal Gaweda
