- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi again
I'm still struggling with the same model. For some reason I cannot plot the results for the movable load. It would seem as if some setting had been changed inadvertently because I'm almost sure of having seen it. Even if I redo the model from a previous version I end up with the same issue. Could someone have a look? I attach the model again.
Also what are the + and - load cases created from default?
Many thanks in advance
Antonio
@antonio.lafuente Artur Kosakowski edited the topic from 'How to define moving load in vertical (YZ) plane' for better findability
