No material error
No material error
HoshangMustafa
Advisor Advisor
No material error
HoshangMustafa
Hi all
Please find the attached file:
How one can solve the no material error?
Rafacascudo
Try re-assigning the material to the thickness . It normally corrects the problem. assigning any thickness solved the problem here
Rafael Medeiros
HoshangMustafa
Hi @Rafacascudo
Your help is highly appreciated.
How would you model a depression in a flat plate?  GF-11 in the attached file. This is a plant area.
Rafacascudo
If you mean that GF11 is a small slab in a lower level connected to the main slab above by 4 walls/beams , probably I would model the walls as  shell panels
Rafael Medeiros
HoshangMustafa
Hi @Rafacascudo
These 4 walls/beams modeled as shell panels would be in tension, since it would act as hangers connecting the small slab to the main slab above, isn't it? If so, should it be reinforced concrete or steel?
Rafacascudo
nerver saw done with steel beam. Normal solution would be concrete
Rafael Medeiros
