Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
No material error
5 REPLIES 5
HoshangMustafa
183 Views, 5 Replies
No material error
Hi all
Please find the attached file:
How one can solve the no material error?
5 REPLIES 5
Try re-assigning the material to the thickness . It normally corrects the problem. assigning any thickness solved the problem here
Rafael Medeiros
Hi @Rafacascudo
Your help is highly appreciated.
How would you model a depression in a flat plate?  GF-11 in the attached file. This is a plant area.
If you mean that GF11 is a small slab in a lower level connected to the main slab above by 4 walls/beams , probably I would model the walls as  shell panels
Rafael Medeiros
Hi @Rafacascudo
These 4 walls/beams modeled as shell panels would be in tension, since it would act as hangers connecting the small slab to the main slab above, isn't it? If so, should it be reinforced concrete or steel?
nerver saw done with steel beam. Normal solution would be concrete
Rafael Medeiros
