GET ENVELOPE FORCES BAR VIA API (C#)
eng_leandromartins
Message 1 of 9
eng_leandromartins
Hello everyone,
How do I get the envelope of all combinations from the beginning and end of each bar?
I wrote the code below but it goes through all combinations and all bars. It takes too long.
I saw several examples on the forum, but I didn't quite understand the logic applied.
 public List<InternalForces> GetInternalForces()
     List<double> FX = new List<double>();
     RobotCaseCollection caseCollection = new RobotCaseCollection();
     rSelection = RobotApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_CASE);
     ForceServer = RobotApp.Project.Structure.Results.Bars.Forces;
     rSelection.AddText("todos");
     caseCollection = RobotApp.Project.Structure.Cases.GetMany(rSelection);
     if (RobotApp.Project.Structure.Results.Available == -1 )
         for (int i = 0; i < OrdenadesProfiles.Count; i++)
             for (int j = 1; j < caseCollection.Count; j++)
                 if (CaseType == IRobotCaseAnalizeType.I_CAT_COMB || CaseType == IRobotCaseAnalizeType.I_CAT_COMB_CODE || CaseType == IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR)
                     robotCase = caseCollection.Get(j);
                     int casNumber = robotCase.Number;
                     DataForce = ForceServer.Value(OrdenadesProfiles[i].Number, casNumber, 0.0);
                     FX.Add(DataForce.FX);
                     DataForce = ForceServer.Value(OrdenadesProfiles[i].Number, casNumber, 1.0);
         BarNumber = OrdenadesProfiles[i].Number;
             FXMax = FX.Max();
             FXMin = FX.Min();
         internalForces.Add(new InternalForces(BarNumber,FXMax, FXMin));
     else
         MessageBox.Show("Modelo sem Resultados!","AVISO",MessageBoxButtons.OK);
     return internalForces;
Thanks in advance
Replies (8)
Message 2 of 9
Stephane.kapetanovic
HI @eng_leandromartins
you should read this topic (msg 15): (API) Macro for dumping all opened tables in Robot (with all tabs) to Excel
note that you can change IRobotTableDataType.I_TDT_DEFAULT to I_TDT_ENVELOPE in Sub GetBarForcesByTable
static void GetBarForceEnvelopeByTable(string bText, string cText, int n) {
    var tb = new RobotApplication().Project.ViewMngr.CreateTable(I_TT_FORCES, I_TDT_ENVELOPE);
    tb.Select(I_ST_BAR, bText); tb.Select(I_ST_CASE, cText); tb.Configuration.SetValue(I_TCV_NUMBER_OF_DIVISION_POINTS, n);
    string fullPath = Path.Combine(Path.GetTempPath(), "forces.txt");
    if (tb.Printable.SaveToFile(fullPath, I_OFF_TEXT))
        File.ReadAllLines(fullPath).Skip(1).Select(line => string.Concat(line.Split(';').Select(s => $"{s,-15}"))).ToList().ForEach(WriteLine);
    tb.Window.SendMessage(0x10, 0, 0); WriteLine("Press any key to continue..."); ReadKey();
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 9
eng_leandromartins
Thanks for the answer Stephane,
One question, how do I create a List through this?
I don't want to save this information in any file. I want to create a List and get this information in another method.
Message 4 of 9
Hi @eng_leandromartins
Have you tried the code?
The code does the following:
- creates a table of envelope forces in robot
- exports the table in csv format and closes it
- opens the file and reads it in its entirety
- it displays all the values by column in console mode
With this you have everything you need to create lists, sort and classify your data.
It's not just a file output. this is a normal process.
Why create a list? Which one? What's it for? I can't guess what you want to do.
Best Regards
Message 5 of 9
eng_leandromartins
I tested it, and I realized that the best way to do what I need is to use this file that this method generates and create a list through it.
Sorry for not making it clear what I want to do @Stephane.kapetanovic
I created an app that uses Robot information to create a model within Tekla Structures, and I want to put this force information inside the parts that are created within Tekla, as user information! And the best way to do this is through a list of parts. So I thought about creating a List directly with the Robot information. But as you showed me, the best way is through this file.
Thanks again!!!
Message 6 of 9
hi @eng_leandromartins
In this case you should add the object IDs of your two models to this list so that you can update your data.
note that you can obtain a list of forces in csv format without using the API.
Best Regards
Message 7 of 9
eng_leandromartins
Thanks for the tip about the IDs @Stephane.kapetanovic!
Do you have a tutorial on how to create or get these IDs in Robot?
Message 8 of 9
     RobotApplication RobApp = new RobotApplication();
    RobotStructure Structure = RobApp.Project.Structure;
       RobotNodeServer Nodes = Structure.Nodes;
         RobotBarServer Bars = Structure.Bars;
RobotObjObjectServer Objects = Structure.Objects;
     RobotNode n = (RobotNode)Nodes.Get(1);        int Nod_ID = n.UniqueId;
      RobotBar b = (RobotBar)Bars.Get(1);          int Bar_ID = b.UniqueId;
RobotObjObject o = (RobotObjObject)Objects.Get(1); int Obj_ID = o.UniqueId;
int Nod_Number = Nodes.GetUniqueId(Nod_ID);        RobotNode n1 = (RobotNode)Nodes.Get(Nod_Number);
int Bar_Number = Bars.GetUniqueId(Bar_ID);          RobotBar b1 = (RobotBar)Bars.Get(Bar_Number);
int Obj_Number = Objects.GetUniqueId(Obj_ID); RobotObjObject o1 = (RobotObjObject)Objects.Get(Obj_Number);
Message 9 of 9
eng_leandromartins
Thank's so much!
