No elements under compression to run buckling analysis Error.
mr.co_su
Message 1 of 9
mr.co_su
When I was trying to analyze the buckling of a compressed bar, robot structural analysis keeps telling me that there are no elements under compression although there is an element that's compressed. And I have got accurate results when i modeled the same bar in SAP2000.
The example: first Picture.
The model: second picture.
The error: third picture.
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mr.co_su
Could you attach the Robot model (rtd file)?
Artur Kosakowski
Message 3 of 9
mr.co_su
Sorry for my late reply, I've attached the file.
Thanks!
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mr.co_su
For such boundary conditions you have to have some nodes defined along the bar element:
I'm attaching the corresponding model too.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 9
mgDDJJW
Observer
Observer
Hello Artur,
I'm struggling with the same problem. In my model of 3D truss construction I have bars which are either tensioned or compressed, there's no doubt about it, but the solver always shows the message "No elements under compression to run buckling analysis".
I have already tried your solution proposed above to divide the bars into more elements and increase calculation nodes, but it seems to not work in my case - I keep receiving the same error message all the time.
I'm running out of ideas what could be the reason?...
Thanks in advance for any help.
Marcin
Message 6 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mgDDJJW
Could you zip and attach the model?
Artur Kosakowski
Message 7 of 9
mgDDJJW
Observer
Observer
Yes, sure. That's just the part of a bigger structure but shows the problem.
Thanks in advance!
Marcin
Message 8 of 9
Simau
Hi @mgDDJJW
There is no load in case DL2, add selfweight
M. Agayr
Message 9 of 9
mgDDJJW
Observer
Observer
Gosh, how can be so blind?....Smiley Frustrated
Many thanks @Simau
Marcin
