No convergence of nonlinear problem! Very Simple model
Message 1 of 12
Hey
My first and very simple 2D Frame in ROBOT.
I get the No convergence of nonlinear problem error when analysis. It is part of my 2. semester project. All is calculated by hand, and i am just trying to see if i can get the same, or just about, results in ROBOT.
The model is attached.
Regards
Sune
Replies (11)
Message 2 of 12
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 3 of 12
Rafacascudo
Do you really need to use a cable element for the diagonals , or just a "tension only" bar?
Rafael Medeiros
Message 4 of 12
Thanks. I never would have figured that out. Fast and sweet support 🙂
Message 5 of 12
Rafacascudo i guess that would do just as well. Can you point me in the direction as to where i select "tension only" for my diagonal bar?
Message 6 of 12
Rafacascudo
define as a standard bar element and ...
Rafael Medeiros
Message 7 of 12
Thx. Its a steep learning curve. Day 1 with robot 🙂 Your help is much appreciated!
Message 8 of 12
Rafacascudo
Although ,after 15 years (v13.5) of practice and still learning, it´s Not so steep! Maybe the easiest one to learn and operate by far!!
Smiley Very Happy
Rafael Medeiros
Message 9 of 12
Then perhaps you can give me pointers as to how i make my results simple and slick. As for now, we need to compared out hand calculations / dimensioning with a ROBOT analysis.
i would like to get a detailed result for bar nr.4. I will post a result of my best shot so far
Message 10 of 12
Or for a single bar this is what i can do
Message 11 of 12
Rafacascudo
select the bar you want the results  ,then click on menu results/Detailed analysis...
or you can have it also through tables . Right click anywhere / tables.../Forces
and if you need more information in your tables , right click anywhere on table area and click on table columns
Rafael Medeiros
Message 12 of 12
I will give it a try after i get some sleep. Thanks Raf
