Bolt yield stress error value
Dear Support,
I am using ARSA 2015 SP3 WIN 7 PRO.
In some bolt database like:
the bolt yield stress fyb  of some bolt classes are not conform to NF EN 1993 1-8 table 3.1.
see the following value of fyb for bolt class 8.8 in RSA:
this value is different from fyb=640 Mpa found in table 3.1.
I made some tests and found that some bolt class fyb values are correct the other are not.
Please advise.
Thank you in advance.
Wassim
Artur.Kosakowski
Autodesk Support
Autodesk Support
NF is for CM66. Use ISO database instead.
Artur Kosakowski
You are right Artur, the EN ISO bolt database has valid yield stress values !
But I suggest that software gives some warnings of the database incompatibility with the used code (We have the same name of the bolt type between NF and the EN ISO ; Example Bolt  class   8.8 ;   4.6....)
Thank you very much.
Wassim
