Import section database from one model to another
some time ago I created a model which had sections done with "section definition" tool and some fabricated sections done using the standard bar sections tab.
I cannot find the database where the section drawn in "section definition" where saved, but these remain in the model. Is it possible to used them in a different model? how could i do that?
Thank you,
sanjuan100
HoshangMustafa
Hi
Use Section definition>> Save to section database
Please find the attached file.
StefanoPasquini6790
Try this trik:
1) open for first the model where you have all the cross sections you need and check in the section tab if you have all that you need;
2) from this model, open the new model where you want to use/transfert the cross sections.
That's all...
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
You can try with section labels.
labels
Sorted! thanks very much!
