Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Moving loads function has gone missing
6 REPLIES 6
t_ng
1687 Views, 6 Replies
I just noticed that my "Moving Loads" function has gone missing from this morning.
I normally access this function from the following;
Loads - Special Loads - Moving Loads, but for some reasons there is no more "Moving Loads" for me to choose from.
Cheers
6 REPLIES 6
Artur.Kosakowski
in reply to: t_ng
Hi @t_ng
Please try to change the model type to another (Geometry > Structure type) e.g. from Frame to Shell or from Shell to Building and back again.
Artur Kosakowski
t_ng
in reply to: Artur.Kosakowski
Hi Artur,
It works, thank you so much.
Cheers
Thanks for the work around solution Artur! Why this problem is still exist in 2022 version?
when i use 3D frame design i can find the moving load but in building design i cant find it
Rafacascudo
in reply to: bashae_zaiter
Try Tools/Customize menus/loads/special loads and then click on " moving loads" until it turns green
Rafael Medeiros
bashae_zaiter
in reply to: Rafacascudo
Thank you
