I just noticed that my "Moving Loads" function has gone missing from this morning.
I normally access this function from the following;
Loads - Special Loads - Moving Loads, but for some reasons there is no more "Moving Loads" for me to choose from.
Cheers
Solved by bashae_zaiter. Go to Solution.
Solved by Rafacascudo. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
Hi @t_ng
Please try to change the model type to another (Geometry > Structure type) e.g. from Frame to Shell or from Shell to Building and back again.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thanks for the work around solution Artur! Why this problem is still exist in 2022 version?
when i use 3D frame design i can find the moving load but in building design i cant find it
Try Tools/Customize menus/loads/special loads and then click on " moving loads" until it turns green
Rafael Medeiros
