moving loads combination
Message 1 of 21
Hello!
I am trying to use moving loads.
First I am trying in a three spans beam. I defined a moving load with a concentrated load of 250 kN. I got the envelope of bending moments.
I don't know how to combine moving loads with the other actions??
Now I wat to combine moving loads with another actions like temperature and wind. When I made the moving load I got three load cases, the one that I created and one + and another -. But when I combined I can't use cases + and -, why??
Gonçalo Sousa
Replies (20)
Message 2 of 21
Pawel.Pulak
Autodesk Support
Autodesk Support
Cases with + and - are additional load cases containing only top and bottom envelope values and automatically created for compound load cases, i.e. load cases containing many components.
Compound load cases are created in for instance the following situations:
1/ moving load case - many different positions of load
2/ automatic combinations - many different combinations
3/ time history - many time steps
4/ manual combination containing moving load case  - many combinations for different positions of load
In your case you should combine the main moving load case (without + or -) with other loads. The manual combination defined this way will be a compound load case too (see point 4/ above) so it will be also accompanied by additional envelope cases with + and -.
In case of compound load cases the displayed components can be changed using Case component window.
See the screen captures below illustrating it:
- list of load cases for moving load case and manual combination containing moving load casecomb1.png
- component selection for manual combination containing moving load casecomb3.png
If you want to create combinations not for all positions of moving load but only for selected ones you can use "Create a case from component" for these selected positions of moving load and create combinations only with them.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 3 of 21
Thank you for your answer.
My problem is that in COMB1+ and COMB1- I can't see the results. In these combinations I should see the combination of moving load+ with DL1 and movingload- with DL1 respectevely???
Gonçalo Sousa
Message 4 of 21
Pawel.Pulak
Autodesk Support
Autodesk Support
Yes, it should be like in the attached screen capture.
Have you checked that moving load is correctly defined and it gives non-zero results in more than 1 position of vehicle?
Pawel Pulak
Message 5 of 21
Project Info: I am structural design engineeer (BIC PVT LTD)  and we are trying to analyse concrete slab on pretensioned i girders for 28000 mm span for urban metro project (elevated viaduct) .we have modeled the scenario using RSA 2014. The viaduct contains two tracks of metro train . In robot two  moving loads have been deifined for each track respectively.
Problem : We want a combination of dead loads with with both of these moving loads acting together.Tried to make manual combination using two loads but no results were shown (results are displayed when only one moving load is combined with other NON-moving loads .).
How to view envelopes of loads containg both moving loads along with other actions
Message 6 of 21
I am having the same problem as the above post.
I have a structure with 6 moving cranes. I want to consider all cranes operating simultaneiously. I created a combination with the following cases:
61 Crane 1
62 Crane 2
63 Crane 3
64 Crane 4
65 Crane 5
66 Crane 6
This is 10001 COMB1 - when I run the analysis, there is no "COMB1 +" and "COMB1-". But when I only have 1 moving crane in a combination, it will give me the + and - combination.
Help please Artur/Rafal 🙂 !
Message 7 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 8 of 21
Message 9 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
As far as I can see you want to generate 71640450 combinations, but default limit set in job preferences is 64000. Change it and check.
I have never tried to generate so many combinations.
Rafal Gaweda
Message 10 of 21
StefanoPasquini6790
Dear all,
I've a problem with manual combination with moving loads in a bridge with 4 different lanes with 4 different moving loads. As far as I can see, I'm able to do a manual combination for only one moving load, if I add another "moving load case" the combination is empty of results.
Which can be the solution??? Do I have to create a vehicle with the 4 lanes simultaneously?????
here you can find the draft model.
Cheers and thank you in advance, sorry if I ask you a banal question, but I don't design bridges everyday!!!!!!
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 11 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'd consider the following approach:
1. Generate components (positions of the vehicles) for all 4 moving loads
2. Convert the them into simple loads cases
3. Group them into 4 groups with OR (EXCL) operator among cases for the same vehicle in automatic combinations dialog
4. Run automatic generation of combinations
Artur Kosakowski
Message 12 of 21
StefanoPasquini6790
Hi Artur and thank you for your answer, I've done as you said, but the number of combinations is incredible, so....
I've generated all the load cases from the moving loads, then I've edited the load table in excel grouping the load cases using the criterion of the load position. This way I have only 54 load cases instead of 162....it seems that it works...
Now my next step is to double the load position distance, from 1 meter to 2 meters, so that the load cases will became 27....
I let you know my results, Cheers
PasProStudio
Message 13 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Perhaps you can use the influence lines to determine the least favorable positions of the vehicles for given design elements and create combinations in this way?
Artur Kosakowski
Message 14 of 21
Rafacascudo
Hi Stefano ,
I managed to combine all you 3 moving load cases ,through combination tables ,and it seems to be working nice.
changed the step to 3 meters.
Not really sure if it was this you were looking for.
Anyway , finding the worst places toplace the vehicles is also a good option as Artur pointed out.
In your case is the Load Pattern feature ( influence surface )
model with combination attached. saved without results
Rafael Medeiros
Message 15 of 21
StefanoPasquini6790
Thank you Rafa,
this is not exactly what I mean, but it works perfectly.
Sorry if I'm replying you so lately, but I was in Norway for a design competition and there I was not able to open your model.
Cheers a thank you again
PasProStudio
Message 16 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Stefano,
Knowing what you can do I think I may congratulate you on winning the top prize Smiley Happy
All the best.
Artur
Artur Kosakowski
Message 17 of 21
StefanoPasquini6790
Thank you Artur,
I will know the results in two weeks, I'm sure that it will be impossible to win because my opponents are incredibly famous worldwide design firm....anyway we are in final!!!
I will let you know the results.
Cheers!
PasProStudio
Message 18 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
@StefanoPasquini6790
I just wanted to ask for the final result Smiley Wink
Artur Kosakowski
Message 19 of 21
Rafacascudo
he came in 2nd place . Lost to Benoy by 2 points only!!!!
http://www.benoy.com/
Rafael Medeiros
Message 20 of 21
StefanoPasquini6790
Yes it is......I'm still desperate for this result, but it's like to loose versus Real Mardid!!!!!
I will send you privately our presentation.
Cheers.
PasProStudio
