BUG? Surface load in local direction on panels
Message 1 of 11
I seem to have a problem applying surface loads on panels in the local Z direction. When applying a global load to all panels it all works fine, but when switching to local direction some/a lot of the loads dissapear. I can't figure out how to solve this issue.
I've attached a screenshot of the structure with the applied loads. All panels should have a load, but they don't.
Replies (10)
Message 2 of 11
I've had this before and some of my colleagues experienced this today too
Message 3 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Andreas, Tony,
send us this file, if you do not want to share it publicly use private message, generate link by wetransfer or filemail
Rafal Gaweda
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 5 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Andreas,
Use v.2013.
Rafal Gaweda
Message 6 of 11
🙂 Thanks that's very nice!
Unfortunatly we don't have v. 2013 in the company. Is is a bug releated to the 2012 version?
Message 7 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Andreas you are using EDU version Smiley Happy
Let's say it is limitation of this version.
Different tolerance of checking flatness of panels
See below, depending on tolerance this panel can be assumed as flat or not
(Application attached ; assumptions: firts three points of contours \ panels \ claddings are treated as points definig surface)
Rafal Gaweda
Message 8 of 11
Rafal is that a model of the death star?
Message 9 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
No, one of new Darth Vader's helmets.
Rafal Gaweda
Message 10 of 11
Haha, yes I'm trying to model  the pressure on Darth Vader's helmet if he were to go scuba diving 🙂
The preliminary version was created by an EngD student working for us, that's why it's in the EDU format. Guess we have to model it from scratch again 😞
Thanks for your help!
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Your choice.
My suggestions:
1. Download , install and use 30 day trial version of 2013
or
2. Flaten panels in 2012 version ie by addin attached (corrected version of previous one) and correct the worst panels (replace them by triangles), connect them properly (do noy use kinamatic links)
(model sent to you in PM)
or
3. Remove panels, leave bars, basing on bar nodes \ nodes create trianglar panels.
Rafal Gaweda
