Modelling Issues
Modelling Issues
rameez.iqbal
Modelling Issues
rameez.iqbal
Hi.
I have modeled a building wherein the Steel Beams are connected to RC Walls. For application of DL and LL only, I have deflection issues (Pl see attached model).
I presume it to be modeling issues. Can you please review the model and help me out as to where the issue is arising.
Thanks in advance.
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Direction of the orthotropy cannot be defined in the direction perpendicular to a panel (as reduction factors are 1 I replaced all orho thickness with standard iones)
2. Excessive releases in node 618
3. Blocked RX rotations
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
