File size over 3GB
File size over 3GB
vuk.vukanic
File size over 3GB
vuk.vukanic
Hi all.
I could use some help figuring out why my file is over 3GB in size for a simple structure.
Easy things are not worth the effort
http://www.teamcad.rs
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you save the file without results with a new name and then compress it and attach it?
Artur Kosakowski
vuk.vukanic
Here is the compressed file.
ps. I didn't do anything in the model, just compressed the 3GB file and it came out 900kb. I'm baffled.
https://www.dropbox.com/s/gw2bk9rh1jyu1i8/24460-03-0101_00-CABIN.7z?dl=0
Thank you for you help.
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Open the file in the repair mode
2. Save it under a new name
3. Calculate the model
4. Save it under a new name with results
Artur Kosakowski
vuk.vukanic
That did the trick.
Still wondering what went wrong.........
Thank you
vuk.vukanic
Update:
this made my printout compositon not valid.
When I print only a couple of pages get printed.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to redefine the printout composition. It seems that this is the reason for the huge file size.
Artur Kosakowski
