Modal analysis taking into account static forces
Ludwigswe
Ludwigswe
Hello!
I wonder why I get the same frequency for two different load magnitude?
Case 1 the uniformly distributed load on the bridge is 0,3 kPa and for Case 2 1,0 kPa
Case 1  No. 1 Egentyngd taking account  No. 3 Beläggning(0,3kPa).
Case 2 No. 18 EgenviktFall2 taking account No. 19 Fall2(1,0kPa).
It is mod 10 that I  examine. 5,14Hz
Should be less for Case 2!
See link
https://www.dropbox.com/s/penbo199n6uq92p/ModalAnalysHela.rtd?dl=0
Regards
Ludwig
Artur.Kosakowski
Autodesk Support
Autodesk Support
Unless you consider these loads as masses I'd expect the effect to be visible only when the applied load causes large tension forces in a structure.
Artur Kosakowski
Ludwigswe
I thought that the static load, that i choose too account for, always transforms to masses and that the masses are placed in the area of the structure where the load is assigned!?
I don't understand the formulas in the Help part!
Are both stage carried out each time a "Modal analysist taking into account static forces" runs?
Stage one does not include mass matrix?
Can you please tell me more about how this analys type is working!
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, it is not. You have to convert it into mass. The main objective of this analysis type is to consider the stress level which may be due to pulling the element (a guitar string analogy).
Artur Kosakowski
Ludwigswe
Now I got it!
Dziekuje barza
Artur.Kosakowski
Autodesk Support
Autodesk Support
Smiley Happy
Artur Kosakowski
