Import from AutoCAD surface and line in one step (is it possible?)
Hi everyone! Please help to find solution. I draw my model in autoCAD, region and line (chimney inside steel frame). And I try to export it in ROBOT. But if I export in SAT format I will see only region,and if I export in DWG or DXF i will see only lines, and we need to see both: line and region. How we can do it? Maybe someone now) I will be happy ti get any answer!!!)))
Rafal.Gaweda
Autodesk Support
Autodesk Support
Import SAT
Save rtd
Import dwg
Use Geometry \ Structure \ Insert from file and select previously saved rtd file
Rafal Gaweda
Thank you!  I try this metod! If i assambly two rtd files in one , one geometry displace from origin, and I have to manualy moving to origin, in RTD it is not easy) And one thing else: if I export SAT, it export like inches, but in autocad settings millimeter. ( I start use scale factor than i paste in RTD). In my project I think easely will be just draw surface right in RTD)
