Model warnings
Model warnings
Message 1 of 42
Model warnings
I have 3 warning after calculated a 3 storey RC frame:
-incoherent mesh on edges
-cohesion of the calculation model has been provided by definition of kinematic constraints in incoherent points of finite element mesh
-linear load as not been applied to a pannel
I have tryed to follow other post and change the mesh settings but it is even worse.
I have attached the model file:
http://www.filemail.com/t/36154234cbb54dc9834ae45ca2b1d2d6
thank you
Replies (41)
Message 41 of 42
Artur.Kosakowski
Autodesk Support
Autodesk Support
Sorry but from the attached picture I can't understand how to define the zones and if I have even 1 warning I can't run the calculation for the provided reinforcements.
https://screencast.autodesk.com/main/details/f9b642ea-dfd8-4f1d-8acc-1e962f5984d6
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 42 of 42
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is it possible to generate reinforcement drawing for each direction? (top X, top Y, bottom X and bottom Y)
Only be editing the ones generated in Robot (e.g. in ASD Reinforcement or saved as dxf).
Artur Kosakowski
