I'm new to robot, and I want to do a modal analysis of a church's bell tower. The church is old, and to model its bell tower, I used concrete slabs and shells. My problem is that when I run the model, and check the deformations, I see that my walls are independent from the slabs.
Am I supposed to add a specific support between the walls to connect them to the slabs ? Can anyone help me ?
Thanks.
Solved by Artur.Kosakowski. Go to Solution.
I think you might have missed attaching your model... you need to zip it if you are uploading through the 'Attach file' option of the forum chat
Hi @Anonymous
The meshing could be better (see the attached file) but the main point is to display a shape of vibrations for a single mode at the time.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Thank you so much @Artur.Kosakowski for your fast reply !
You really helped me, I could not see what I was doing wrong.
