I am using Frame 3D and I have created a steel frame with claddings to apply loads. One side of a cladding is near a bar/column and this causes an isolated node to appear. The isolated node sometimes disappears when I change something else in the model (for example a section that doesn't affect this area). I have tried to move the contourpoints of the side of the cladding to exact coordinates to the beginning node of the column, but it's not reliable. The isolated node has type 1 and type 3 instabilities.
Is there a way to manually delete a calculation point or edit them? I have attached a screen capture of a 3 calculation points that are in close proximity to one another. I suppose one point would be enough.
