RC wall design problem (Revit imported)
JPNR87
JPNR87
I have problem with designing wall imported from revit. Wall is not defined correctly error is given. Please help how to solve it.
Thanks!
JPNR87
maybe the problem is that holes are created in REVIT with window
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
You need to design a wall with shape like this (multiple openings) in the same manner as a slab. I'd recommend watching the recording of the 5th Robot webinar (https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td...).
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
JPNR87
This main reinforcement selection is according to global axis I assume?
Thanks for help!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
For this scenario the main reinforcement is in the direction as set in the reinforcement type label assigned to a panel.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
