Modal analysis
Modal analysis
7.JPG1.JPG2.JPG3.JPG4.JPG5.JPG6.JPGHello.
I’ve got some problem during calculating 2-storey building on seismic forces. I created modal case, but the “Rel.mas.UX(%)” and “Rel.mas.Uy(%)” are too low to add seismic case. I tried to increase number of modes up to 50, but I can’t even reach 70% to do residual mode as it was mentioned in one of the Autodesk presentation. I’ve added “Load to Mass Conversion” too, but “Rel.mas.UX(%)” and “Rel.mas.Uy(%)” isn’t rising anyway.
P.S. In RSA there isn’t my country’s seismic codes, so I’m trying to calculate model with the help of spectral method.
Can someone help me solving this problem?
There are some screenshots below.
Replies (13)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
File please.
Rafal Gaweda
Thank you in advance.
 Download File
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Without  Active Mass Direction Z you need 8 modes.
Otherwise 226.
Rafal Gaweda
@Rafal.Gaweda
When I turned off Active Mass Direction Z, for all modes “Rel.mas.UZ(%)” =0  it worked (percentage is higher than 70%)
According to this, I have another question:
Is it reasonable to turn off Z direction, in this calculation?
Is it okay, that for main modes, such as 1; 2; and 3,  “Rel.mas.UX(%)” and “Rel.mas.UY(%)” are lass than 70% ?
Simau
Hi @Anonymous
NO, because you have very heavily loaded beams in case 2, so you can't neglect the vertical vibration of these beams.
Moreover, you  already reach 90% of mass in mode 4 for Z.
M. Agayr
Simau
@Anonymous
your structure is very steep in the first level.
If you consider that the other floors are embedded in the first level you already get 82% in X from mode 2
M. Agayr
Hi @Simau
Firstly, thank you for response.
Is it enough, to continue calculation for seismic case, regardless  masses for X and Y aren't reached 70% ?
Your structure is very steep in the first level.
The vertical reinforced  wall (concrete plinth) in the first level is due to there are horizontal loads from ground. That's why it is steep.
To be honest, i didn't understand what you mean, can you explain ?
Simau
Hi @Anonymous
I just wanted to point out that in very stiff structures at the bottom, the masses of these levels are mobilized only at very high frequencies, sometimes exceeding the cutoff frequency of 33Hz.
In this case a good opinion on the seismic behavior of the structure can be obtained by considering the flexible part of the built-in structure in the rigid part.
Looking at the mobilized masses in X and Y below 33 Hz, you are not so far from the 70%, so in my humble opinion you can use the residual mode.
M. Agayr
Simau
Just to complete my point of view, in the substructure model we see that the mobilized mass is 82% at  mode 2.
So in the complete model you are sure to have mobilized all the mass of the upper part of the structure before 33Hz. This upper part being the sensitive part of the building.
M. Agayr
@Simau
Firstly i'm relay interested, if it is necessary to have 60 or more modes for 2-story building?
Secondly, i can't find mobilized mass (82%) in mode 2, and which direction we're talking about? Can you show me where is it, please.
It'd be great if you advice me some manuals about this topic, so that i could read it.
Simau
@Anonymous
Maybe I was not clear enough, sorry
it is not a matter of number of modes, the goal is to  know if the number of mode retained is sufficient to estimate the efforts in the part of the structure which interests you.
In this case, it is the upper part of your structure that is sensitive to earthquakes. In the model (sous-structure) of this part alone, you can see that  mobilized mass is almost 100% in X and Y with only  with 7 modes.
It would be good if you compare the efforts in some elements of the high part obtained with 7 modes in these models with and without the lower part.
The 80% in mode 2 are related  flexible structure only without the lower part, see attached file in post 7.
see attached file (in French :0(  )
M. Agayr
Simau
sorry
first page was missing
here new doc
M. Agayr
hi @Simau
Thank you for response.
It seems, I have much to think about this topic.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
