Minimal internal bending moments
2 REPLIES 2
mariadlugoj01
174 Views, 2 Replies
mariadlugoj01
Hey community
I'm quite new to using robot, and just trying to get the bending moment on the roof, with a superficial load of 100kgf/cm2 and the load being distributed as such
However, I don't understand why the moments are so low in the roof itself and do not match hand calcs. I have not assigned any supports to the upper edges of the walls because that makes the moments 0
This is just with the live load and no combinations as I'm just trying to get the hang of it, I am aware the moments are in the kNm/m units, but they are still pretty low
Any help is appreciated, thank you!
Hey community
2 REPLIES 2
Rafacascudo
in reply to: mariadlugoj01
Rafacascudo
You have to assign shell as the calculation model ,so you can have finite element (analytical) transfer of loads.
With the simplified method you will get wrong results .
Rafael Medeiros
Rafael Medeiros
mariadlugoj01
in reply to: Rafacascudo
mariadlugoj01
You're a lifesaver, thank you so much!
