I have a model of a 8 story concrete building with shear walls. The floors are all shell panels. The initial meshing parameters are as suggested in the videos produced by Autodesk. When I run the analysis (using Robot2015) I have two problems with meshing which I am not able to solve, I would be very grateful if you can help me with the following issues:
As a seperate test I moved the location of shear wall (figure below) and the meshing pattern , can you please explain the reason?
Kind regards
Solved by Rafal.Gaweda. Go to Solution.
Correct meshing options set - see attached file.
Hi Rafal,
Thanks very much for your response, however I tried your meshing options (as in the figures below) in my original model and I still get the same results. Can you please mention all the parts you changed?
Kind regards
its not the same..... u can see the differences in ticks
i second view from you i can see you have thick on regular mesh, at panel char point and user emiters
in attach there s no ticks 🙂
to off this ticks you need to choose a Dalaunau make changes and return to coons 🙂
sorry for my bad engl
