I am having problems with the meshing for the attached hopper which has a number of steel plate panels. The mesh generated with kinematic constrains looks ok but when calculations run I get a cyclic response. From previous answered topics I have turned kinematic constrains off and used the Iterative adjustment method.
I get a number of errors with this method and resulting mesh is poor. The results also do not look correct.
Would you be able to have a look at the model and advise how to correct it.
Thank you.
Enda
Solved by Rafal.Gaweda. Go to Solution.
Model is not accurate enough - make big zoom in incoherent mesh locations.
Corrected model attached
- some panels geometry corrected (using this: http://forums.autodesk.com/t5/robot-structural-analysis/panel-contour-points-modification-api/m-p/38...
- meshing options set
Check model \ results. It seems due to geometry inaccuracies panels 398 399 413 may not be supported by ribs.
