Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Meshing in Shells
2 REPLIES 2
494 Views, 2 Replies
Meshing in Shells
I'm fairly new to RSA and I'm trying to model a circular shaft with an opening. I want to model the shaft as a shell, but when I try to mesh the object, the inside of the shell, where it should be hollow, is also getting meshed. Any idea on what I'm doing wrong here?
N. Simon
2 REPLIES 2
EduardoMeruvia
Hi @Anonymous ,
Unfortunately, that meshing "issue" is a by product of Robot meshing extruded closed looped profiles.  The way to get around it is to MESH FREEZE and then manually delete the unwanted mesh. After doing that, even if you have to re-mesh again, the mesh should stay as you wanted it.
Hope it helps.
in reply to: EduardoMeruvia
Hi @EduardoMeruvia ,
That makes sense. So if i extrude two half circles instead of a closed circular loop, my issue goes away.
Thanks a bunch!
