Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Mesh problem in results only
3 REPLIES 3
280 Views, 3 Replies
I have an issue where when I turn on the maps and then select a panel with finite element centres on, it shows the mesh is all over the place.
I have take a screen shot of what it looks like.
When I select the panel in normally, it recognises the mesh normally and this only happens when it is in maps.
Gabriel
3 REPLIES 3
Rafal.Gaweda
I am afraid I do not understand what you have done.
PLease explain more precisely or record movie showing what you are doing.
You can do it this way: after selecting pansl(s):
or
Rafal Gaweda
in reply to: Rafal.Gaweda
Sorry, I will try to explain better.
1. I have a plate model which seems to mesh fine. Figure 1.
2. I then turn on maps and display the moments at finite element centres.
3. When I select the mesh again, it starts highlighting other panel's mesh. Figure 2.
I have tried deleting and remeshing but the same thing comes up.
I'm just not sure if this is going anything adverse to my model or if I can ignore it.
Thank you
Gabriel
Rafal.Gaweda
Mesh model, freeze meshes (panels) then calculate,then check.
Rafal Gaweda
