Member Properties not correct in Deflection checks
sshasni
sshasni
Dear Members,
While calculating deflection checks, I am getting wrong Member properties as compared to those while calculating the AISC-360 Design checks. Please find attached both reports and advise how can i get correct member properties in deflection checks. I will be thankful.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @sshasni
Share model with incorrectly regognized section properties for verification.
Save model as RTD without results and zip it before sharing.
Krzysztof Wasik
sshasni
Thank you for your response. Please find attached model.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @sshasni
It seems like issue in American steel codes detailed analysis data, when only displacement (SLS ) is verified. I will try to check it with development tomorrow.
Krzysztof Wasik
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @sshasni
Hi I have confirmed it with development and registered as an issue for correction. As far as I could check incorrect information about properties (while SLS verification) does not have any influence on deflection verification (which is werified  correctly).
Krzysztof Wasik
sshasni
