Member Design to ACC Code Combinations
stefan_keane
Message 1 of 1
stefan_keane
Is there any way to use the ACC Code Combination results generated to design the members in the steel member design section? Currently the steel member calculation dialogue box is limited to ULS and SLS only. Each time I try to add the ACC Code Combination, Robot just deletes it. Calculations are currently set to BS EN 1993-1.
Replies (0)
